Good Morning All!
I have a 1997 Evinrude that was given to me but has some problems. I have not had this motor running or in the water yet. The model is: E50TLEVC (or UC, can't tell from the sticker).
The engine itself looks extremely clean so I am hopeful that it should run OK with a tune-up. The main thing I see right now would be how much the boat might shake/cavitate due to a bent "fin" (not sure of the correct term here) on the lower section of the motor. It is bent/curled sideways and the tip of it is broken off. I have included a couple pictures at the end to give you an idea. I know that the prop is in bad condition too but I have an additional one to replace that.
So I guess these would be my questions:
Beyond that I also had two generic questions about the motor:
Any feedback or suggestions would be greatly appreciated! Thanks!
- How significant of a problem do you think this would be?
- Is there any way to possibly repair the bend?
- Is there any way to possibly repair the broken tip?
- To replace that would I need to replace the whole lower section?
- Does anyone know where to get a manual for it?
- Currently the motor is setup with a seperate gas and oil lines. Is it possible to use this engine with just a single gas+oil mixed line? If so, how?
