The whole story: The first time we had the boat out after purchase last year, the water pump went out, over heated the motor and left us in the middle of the lake. We had that replaced along with a new heat sensor. We got it out one time after that and it worked alright, just puttering around a little. This year, getting ready for the season I changed the lower unit oil, changed the spark plugs, put the muffs on and flushed the cooling system, which looks to be working perfectly. We took the boat out this weekend and everything was fine, until we started running up the lake, we got about three minutes of run time before we got an hot light and warning horn. Shut down, waited about 15 minutes and it started right back up and we headed to the dock, almost exactly the same amount of time back to the dock and it over heated again. The water pump is fucntioning and gives a good solid stream. Any ideas as to why this is happening? Could the VRO be the problem? Any help would be greatly appreciated.
Thanks,
CDBird
Thanks,
CDBird
