Hi Everyone,
This is my first post, long time lurker though.
My family received a 1980 Seanymph Fishing Machine about 5 years ago and the boat has just sit. We are now looking to get it up and running. However, when we received the boat we knew the transom was in bad shape (I mean really bad). You could almost push your finger right through the wood. Without the transom saver the motor would most likely rip off the boat. A couple pics are added at the end to give you an idea. Fortunately the aluminum seems to be free of cracks or rips. However you can see how much the back end is bowed out.
We are going to fix this by ourselves and had a few questions:
Any help you guys can provide would be greatly appreciated! Once we have figured out the materials we need we will just need to figure out how to get the motor off the boat!
- What is the best type of wood to use? The current wood is 1.5" thick. Would laminate beam (like for structural support in a house) be as good as marine plywood?
- What do you suggest to use to seal the wood?
- If marine plywood is the better choice, what should be used to glue the sheets together?
- Given that the motor that is attached to this boat is roughly 200lbs, would it make sense to place a steel plate (or similar) on the visible side of the wood to help reinforce?
