carterslade
- Apr 22, 2012
- 7
Hello, I am carterslade. I have recently purchased a 14 ft. lakeflite fishing boat with a 40 hp. evinrude motor. The boat was owned by an elderly neighbor and has set for two years. I have had it out twice and found the bugs and other gremlins that come with buying an used boat that has set for an extended time. First off the water expel line was stopped up. Paper clip unstopped it. Next no power. Found screw had dropped out of linkage to top carb. Got that taken care of. Next water went from flow to a trickle then stopped. Ok, the impeller probably needs replaced. I can do that. Wrong!?! I have the bolts out of the lower unit and it dropped down about 1 1/2 to 2 inches. Ok, hummm....... call buddy. He says to take shift linkage loose. This is where my confusion goes into overdrive. I have two cables coming in on the side of the motor. I know one is throttle and one is shift. Where is the shift linkage that I am suppose to take loose. The motor is a 40 hp e40eccs. I have looked a diagrams on the i-net and have a book ordered that I will pick up tomorrow. thanks
