Got a new mercury 25hp efi was going through break in at 3/4 or full throttle it will run for about a min then cuts out like its starving for gas runs fine at idle then does the same thing. Tank is venting good as I took the cap off to make sure. I ran it with the hood off and can still see gas in the fuel filter also. Any help or thoughts would be awesome. Thanks
