150 stalling when accelerate fast ( bogging)
boone68
it had the vro pump but it was removed and electic fuel pump was put in and the gas is mixed in the tank any suggestion to fix the problem
OutOfControl
Re: 150 stalling when accelerate fast ( bogging)
boone, not enough info.
Please post the year and model# to help narrow the problem. Did the motor run correctly before the VRO removal? In the meantime, check and clean the internal fuel filter and replace any inline filters.
emdsapmgr
Will the engine run the boat normally at WOT?
boone68
It is a evinrude150xp model number e150stlcca year 1988
SparkieBoat
follow the instructions in my sig below
cdn-pk
sometimes they just need a good link and sync. the carbs should start to open up before the timing is advanced. but otherwise +1 for what sparkie says!
