Browning117
- Apr 21, 2012
- 2
What's up guy's, I'm having a hard time with this issue on my buddy's boat. The power trim unit needs to be replaced and I've started that process already. I ordered the new assembly already and I'm ready to put it in, but the old one won't come off. I removed all the bolts (6 of them), have the motor propped up on a chair so it's out of the way and it won't come out. It's loose and moves all around, it's like a ghost is holding it in. Do I have to remove the whole motor and housing unit or what? I can tell that the cylinder on the right (as you are looking at it) is hitting the top of the mount that holds the motor. As we speak, I have an engine hoist around the motor and ready to lift the whole thing off, before I did I just decided to ask if someone knows more than me. I'm mechanically inclined but I've never ever done anything with boats or motors. The reason I don't want to remove it if I don't have to is because the previous owner must have broken the back part of the boat, the part that holds the motor on. The fiberglass is cracked and he or someone else repaired it by running a thick piece of steel outside and inside and bolting them together. Well, these bolts are attached to the mount that the motor is on. Basically, it's a b**** and I have no room for error. Someone please help!!! If you want to you can call me, the name is Brian and I would appreciate any kind of help. I can also send u pics and short videos from my I-phone, call me anytime, 559-786-0671. I don't care if it's 3 in the morning, I just need help
