Re: bilge wiring help?
Assuming you have a 3 position switch controlling the pump, one direction is ON bypassing the float switch, the opposite direction is ON but only provides power to the float switch that then controls the pump and a third position, usually center, is OFF.
Fireman's got it right, Here's what the manufacturer says:
Brown (Positive) wire will connect directly to the Automatic side of the panel switch or power supply, if Brown wire is connected directly to power supply it needs to be properly fuse protected.
Connect the Brown/White trace (Positive) wire directly to the Manual side of panel switch. If the Manual override feature is not used this wire must be sealed to prevent water intrusion.
Connect the Black (Negative) wire to the Negative battery terminal or Negative Buss bar.
Wire the Bilge pump directly to power supply, this ensures the pump has power if the system on boat has been isolated.
http://www.xylemflowcontrol.com/sup...rized-or-rule-mate-pump-to-a-panel-switch.htm
- Grandad
