I recently bought a 24' playcraft pontoon with this 1975 MERC 850 (I'm assuming) serial # 4296995.
I took it to a recommended merc vet mechanic and he rebuilt carbs, replaced stator wires, coil, rectifier, and got it running great. After about 3 or 4 days out the motor was idling and all of a sudden died. I pulled the cover and noticed the insulationi on one of the connectors for the wires coming from the switch box had vibrated down the wire leaving the connector exposed. Im assuming this shorted out on the case of the motor and caused the issue.
I took the motor to U.S. Boatworks in Kansas City, KS and they said the coil had a weak spark and replaced it. When i got it back the motor would start only with the rev switch all the way forward. It would also rev quickly then immediately die. After this happened for about 5 minutes I was able to get it to idle and run properly. I ran it across the lake about 10 minutes and as soon as reduced to idle speed it died.
Now it will not start. Does this sound like the switch box is bad from shorting out and causes the coil to go bad as well (maybe the new coil bandaded the problem for a very short time?)
If anyone is educated on these motors (MERC850 out there?) please let me know what you think. I am only 26 so I don't know much about these old things and i'm trying to fix this one cheap (I have about a $1000 budget for a motor for this boat)
