I have a 1956 Evinrude Fastwin 15 that has been giving me trouble, but I think I have found the problem, I would just like a second opinion from those more knowledgeable before I start tearing things apart.
I could never get my engine to run for more than a few seconds before it would die. I did some looking online and found it might be the compression, i.e. not enough to get a good combustion. I don't have a pressure gauge to determine my exact compression, but I can hold my thumb over the spark plug hole and turn it over, so I'm guessing it is less than desirable. I had been attempting to use a 24:1 oil/gas ratio as suggested on here. I added a little more gas (about a 12:1 ratio) and it ran fine, just smoked a lot. Don't worry, I only did this for about a minute.
My thought now is I need a set of rings. The cylinders themselves are fine, no scoring. My biggest question is: Is there anything else that I need to do to improve compression?
