Re: 90' Force 50hp- 1/2 speed @ wot
Seems unusual that it would start easier on muffs. Post a bit more history- engine year model, owned it for so long, ran fine last summer, heard a bang and it didn't run as well? Sat idle for 3 years before I started it up?
Mostly, you start with a compression test, and post the results. Your problem could be anything from compression to spark to fuel. If you have good compression, then check the spark. if you have good spark, then it's the fuel. usually the fuel pump can wear, and you can re-build yourself for a pittance. You can also have clogged fuel lines? Do you have a water/fuel seperator? Do you have an inline fuel filter?
i am asking more questions than giving you answers, but as they say, questions are the answer.
Post results and we'll go from there.
Cheers
BTW- Welcome to the forum. The best forum on planet Earth.
