Re: Exhaust Manifold Riser?
Yes.
the riser bolts to the manifold. The exhaust (and water) exit through the rubber hose linking the riser to the ypipe and then out through the drive. You may have a clog in the manifold or riser causing the overheat issue. Have you changed your impeller recently?
