Mariner 50 HP Compression
Excalibur5
Hi sadly my force 70hp blew up on sunday and was towed in by the coastguard. Looking at a 50hp mariner as a replacement. Does anyone know what the compression should be on each cylinder?
JB
Re: Mariner 50 HP Compression
Measured psi varies too much with gauges and technique to quote psi.
If you do the compression test EXACTLY as described in the Engine FAQs with a good gauge, you should get both cylinders within 10% of each other and over about 100psi. The 10% is the important part.
