At the end of last season, I was removing the water drain plugs from my Mercruiser, I/O 4.3 liter engine block. The ones that are on either side of the under side of the block. One came out and the threads are rusted and in bad shape. I may be able to put a screw plug back into it though. The other one snapped off leaving half of the threaded drain plug in the hole. I have tried a screw extrator with no success because it is so corroded and frozen into the hole. The space is so tight that I can't get into it with a drill to drill it out and not ruin the threads, if there are even any threads left.
My question is: Are there any type of plugs that you do not have to screw into these holes to plug the drain? Does anyone have any suggestions. I am at a loss here and have no options left, that I know of. The engine runs great, but these two holes are a big problem. Any help would be much much appriciated!!
Thanks.
Thanks.
