what is the normal voltage that outputs from an outboard coil and does size of engine(hp) matter as to which type of coil i can use . my coils are of the cm61-21 type could i use cm61-28 type. i have also heard that you can use some yamaha motor cycle coils.is this true? ?????????????????????????????
cheers
cheers
