sportcraft88
- Jun 9, 2011
- 16
This is my second season owning my boat, last season it had some issues, but i just dealt with them, now I just want to get it running smoothly. Some details, the motor is still running the VRO pump, I have only had the boat 2 years and the previous owner did not keep very good records, but the pump had a tag on it that said "Ethanol safe" or something like that. does that mean it is a newer pump? im assuming ethanol wasnt an issue in '86. I was running champion plugs until yesterday, i switched to the NGK BZ7HS-10's. Compression is 115ish on all 3cyl (is that good?). I recently went through whole fuel and oil system and tightened and retightened all hose clamps to make sure there were not air leaks. I did a de-carb on the motor today and took it to the water today to test it out. Motor seems to run smoother but im still haveing the same major issue. The motor will idle great, and runs at WOT great(runs about 33mph on a 16' sportcraft). but at trolling speed it will run for maybe 10 seconds then sputter and stall out. If i can get it back out of gear in time it will idle back up fine. When it cuts off, its difficult to start back up and smokes alot when it does start. I have noticed when i take the hood off the carbs that there seems to be more fuel sitting in the carb than there should be at idle. But then again I dont know how much there should be, if any. I put a new primer bulb on it today, pumps up good and hard, and softens a good bit after running. The carbs were supposedly rebuilt, but I cant be sure. The marina i took it too absolutely robbed me, had a $1600 list of stuff they "fixed". Most of which was not touched, ie new fuel line, vent hose, carb kits, and much much more. I raised hell considering they told me over the phone after they "diagnosed the problem" that it would be less than $300. One thing I feel could be the problem is flooding due to a stuck float? How can i test VRO to see if it is failing? What else should i be looking at?
Sorry for the long post but I would rather give all the info i can think of
The motor is actually an 87, mistyped the title.
