I have a 98 20ft seaswirl bowrider with a 5.0ho ford motor and xolvo sx outdrive. Im having problems with the trim not working. Today I took the blue and green wires off the trim motor and used a battery and the motor goes up and down like a brand new one. I put the wires back on the long rectangular relay and when you push the up trim button both the blue and green wires have power. When you push the down button both have power also. I took the wires off again and when one has power and one has ground it works as it should. Do you think the relay has gone bad? Or possibly the switch on the throttle?
thanks alot,
brad
thanks alot,
brad
