5.7 alpha one outdrive problems
edge4you
ok, i have read many posts on this site and have done the the following, first background info. bought boat this winter and started it yesterday, cranked and ran good, went to put in forward and made a grinding or clicking noise, thought maybe shift cable, i unhooked shift cable at engine and manually shifted , still made noise, but noticed noise was coming from lower on outdrive, turned engine off and left in gear, and turned prop, it turned one way smooth with a little noise and turned other way with clicking noise, iam at end of my knowledge base any help would be awesome, thanks
1990 bayliner 2556
ktbarrentine
Re: 5.7 alpha one outdrive problems
I am sure you will get lots of response and some follow-up questions, like: Are you running on muffs? Are you trying to run your prop out of the water? When you turned it off and left it in gear, was it foward or reverse? Which way did you then try to turn the prop? (with shifter in forward, the prop should turn clockwise with a ratcheting (clicking) feel, and should lock when trying to turn in reverse (counterclockwise). Sounds like there's no gear damage in the lower, but I think we need more data.
edge4you
ok here is more info
running prop out of water with muffs on and water flowing, it was in forward gear when tried to turn prop, update while in forward gear when turn clockwise with a ratcheting sound, when turn clockwise will catch sometimes, mean i will jiggle prop and will catch then spin clockwise and spin counterclockwise will sometimes catch. check oil fill cap very little metal.
Pete104
Keep reading more posts. It's perfectly normal!!!
Ayuh,... When runnin',... With a Brisk shift, it should clunk once, 'n be in forward.... Ditto for reverse...
If it Don't, 'n ya can't manually shift it at the shift switch by hand like ya did,....
Ya probably need a New lower cable, 'n at look around at the rest of the drive...
edge4you
when i manully put in reverse will not catch acts like it is in neutral,but will catch when manually put in forward sometimes.
outdrive was rebuilt about 4 yrs ago, and looks good, could it be the lower cable is there a way to check before i buy one. also boat sat up for 2 yrs in alaska.
Ayuh,.... I'd go ahead, 'n buy All the rubber parts in the transom,... she's due....
The lower shift cable, 'n the Bellows.... All the bellows....
Look up in the Adults Only section at the top of this forum for some Great info, 'n the manuals you'll need...
