Re: no purple wire on new rectifier,tach don't work
Maybe a bad tach or probs with the gray wire going to it. How do you know it's charging ?? Also could have wires that go to the tach that power it up with probs. The new reg/rect's don't require the purple wire.
tach doesnt care where it gets +12 as long as you dont use the grey wire which is for tach signal only. does seem weird that they would leave off the purple wire
dam learn something everyday. i always thought the purple was hot due to the motor not the key. kinda makes sense now why you dont need the purple and why the gauges shut down when the motor does. sry for the bad advise
