Tooth Ferry
- Aug 25, 2005
- 3
I have a 1990 Sea Ray 7.4l Bravo One that was working fine this weekend. Then I lost forward. It wouldn't engage into forward. We were able to use reverse for about an hour then lost it also.<br />Shift cable appears to have full travel. And I am able to manually shift gears via shift lever on outdrive(has been removed from the boat). I was told that outdrive is known for clutch failures.<br />Any ideas and how can I verify a clutch failure?If it has failed would I be able to engage it like I am?
