Denis Gibson
- Apr 16, 2012
- 3
Hi like a number of thread beginnings I have read I am also new to forums. I like nostalgia and have been restoring a 6Mt glass boat that has an AQ170 engine running a 270 2.15:1 leg with a 15/15 prop. The engine has been overhauled and had new rings, all new valves carbi kits, electrics ect and actually runs very nicely the plugs are a good colour but unfortunately I have come to the conclusion it is lacking in power firstly as I have only ever been able to achieve a max of 24 knots at 4500 rpm with this prop and the prop guy's tell me it should achieve 30 knots minimum with this set up. I have also done some extensive inspection of the hull but it is also fine.
What leads me to consider lack of power is when the boat is performing at its best the carbi butterfly's are only half open and it makes no difference to the operation of the engine if they are fully opened or anywhere in between. I have considered the usual suspects being either incorrect combustion air flow, electrics or fuel and I am fairly confident it is not combustion air or electrics so that leaves fuel it has 3 x Solex P44 carbi's of unknown origan so as a first I would like to know what size the main jets should be or if anyone can suggest another area to look it would be much appreciated.
Thanks
Denis
Thanks
Denis
