iBoaters,
I'm having some trouble with my trim system. Having got all of the pieces back together after 10mons of tear down and rebuild, my initial excursion with the boat was delayed by a trim motor that didn't work. I kind of expected it as the boat had sat untouched for roughly four years (previous owner). With a fresh battery hooked up, I could hear both of the relays clicking when depressing the trim switch, but no motor functioning. I cleaned all the ground connections and was able to get it to work reliably (in the drivewaywithout any troubling symptoms.
I took the boat out for a shakedown run on Sunday and, after about 10minutes underway the trim up stopped working. Momentarily pressing trim down would activate the motor. Pressing up (requiring much more energy) resulted in nothing. Got it back to the dock, and the same pre-functioning symptom existed - pressing the trim up switch resulted in a "click" at the relay, so I'm assuming all fuses are intact. In an effort to troubleshoot and get the drive up, I flip-flopped the lines (pressing the switch down to trim the motor up). It worked for the two seconds I kept the switch depressed. I stopped to check if the motor was indeed trimming up, which I believe it did. Trying again to continue and I got the same "click". I ended up having to disconnect the lines and ratchet the drive up with a come along (phew!).
I haven't yet gone through a full diagnostic process per the instructions on the sticky thread. Primarily because the relays are such a PITA to unplug (any tips?). I suspect that since I could get the motor to work in one direction, I might be current limited. My first plan is to try and clean/replace the admittedly shoddy looking connections on the power side.Do you think this could be bad relays? I hate to admit, but I ran the boat without the seat and lay-out platform, i.e. the motor and battery were subject to sea-spray. This was primarily to allow for ease of access and viewing (this has all been my first go-round); I realize now that this is not the way to go.
Any suggestions/comments as to likely culprits and fixes would be greatly appreciated.
Thanks,
Joe
Thanks,
Joe
