Good evening folks,
Worked on my 1969 40hp Big Twin Lark this weekend. Began with some re-wiring on the engine as you will see in the pics below. Also removed the electric choke (as it was busted beyond repair) along with the exhaust/heat exchange conduit to the electric choke control (which was also busted).
I plugged the top heat exchanger hole with a plug (screwed in), but was wondering if the bottom heat exchanger hole needed to be plugged too? You will see in the pic below that I screwed plugs into both.
Am I OK in doing this? Does the bottom screw hole need to be left open for heat exchange/cooling of some sort? Should I leave both open?
Any help is good help...
http://i1072.photobucket.com/albums/w368/Jwdspics/5b5d35fb.jpg
Re-wired...http://i1072.photobucket.com/albums/w368/Jwdspics/f906a8ce.jpg
Thanx!
JD
Thanx!
JD
