Tiny Tach vs Quicksilver Service Monitor
jcalder3
Hello,
It's seems as though the Quicksilver Service Monitor is manufactured by Tiny Tach. Is this correct? If so, are the specs for the Quicksilver version the same as the Tiny Tach? I've read the Quicksilver can read the RPM's and has a re-settable job meter, but does it also record the total engine run time (doesn't reset when the job meter is reset) like the Tiny Tach?
Thank you
