Re: guys who went from vro to standard fuel pump
I really need some help here. I have been told so much bs I dont know whats right from wrong. I have a johnson 140 hp 1985, was having and still having a fuel issue. I disconnected the vro side of the pump and its running much better still sneezing ,coughing and stalling coming out of wot.
Things to look for there-
The throttle system needs to be synchronized. If you haven't done this or don't know what this is referring to then i'd bet it's a large part of the problem. If you do some searching around this forum or google then you'll come up with good directions but the factory manual is the best reference.
Idle timing needs to be set. Factory manual.
Carburetor fuel jet and idle air bleeders (like jets but they meter just air) and all passages inside the carbs need to be clean and free. Dirty carbs will cause the problems you're having.
I dont think it has the power to pull enough fuel because the primmer ball goes soft and you cant see gas in the filter. At low speeds it is perfect. It would'nt even idel long when the vro was hooked up. Is there a fuel pump that can replace the vro/fuel pump.If so can I get a part #.
Check every fuel line connection from the tank to the motor. The lines can fray and connections can be loose. If something is frayed then unhook the line and cut it off a half inch or whatever it takes to get fresh rubber. Only use marine hose clamps for fuel lines if at all possible (unless you just can't reach something) because zip ties won't cut it. You'll leak air into the lines.
Check for a closed tank vent. If a vent is closed then your pump won't be able to overcome it.
Also would the fuel to oil ratio be 50:1 or should it be leaner, richer. Thank you for any feed back
The fuel ratio should be 50:1.
