Re: 1974 Starcraft
Thank you for your reply: The boat is 18' CC 1995 Suzuki outboard. Transom and the deck were MIA when I bought the boat. My son and I have been bucking rivets on and off for two days now
But still going over them one buy one. I am a welder buy trade and the first thing I thought of was to replace the transom with an alum frame. Weld the frame to the ?” on one side and rivet one side then weld all around. The frame or transom replacement will slide into the channels that are still on the boat. Blind rivet or self taping SS screws to secure to the channels. But being my first rebuild of a boat what I think and what is the correct thing to do are probably very different.
Ayuh,... Mine's 21', I/O.... You could build it like that,...
I replaced the mid-ship bulkheads with welded aluminum frames, with plywood fillers, just to screw into...
The cross brace piece under the forward windshield is also framed aluminum...
I also use alota 3/16" closed end pop rivets,... work Great,...
If yer rebuckin' all those rivets, ya must think she leaks,...
If so,... Coat the seams with Glu-vit, before ya closed her back up....
