65chevelle
- Apr 15, 2012
- 10
My first post. I am replacing the pistons in my Force 125,I have them out used the trick going thought the reed ports.
The engine ran good but had low compression and would not idle it had no noises, so should I replace the rod bearings or reuse them they look good. any other suggestions are welcome as this is my first outboard piston replacement. Thanks
