OMC Stock Props
Roadrager50
I have a 1977 Thunderbird with a 190 OMC. The boat came with three props and all of them have damage to the fins. I have two aluminum,two different pitches and a bronze prop. I need to know where I can get a new prop,or get mine repaired.
steelespike
Re: OMC Stock Props
There must be some prop shops in your area that can repair your props.
The size is usually in the area under the prop nut. _ _ X _ _ (diameter X pitch) pitch is the key number.
When you get the sizes let us know what they are. Get us as much info as possible from "read this first" on
the first prop page.
Roadrager50
Re: OMC Stock Props
Thanks for the advice. I had read that first and saw no reason to post that info since I was asking mainly where I could purchase a new one. So if I need to post.....Here it is #1 is 14x17 #2 is 14x19 both aluminum and the bronze one is 14x17 all of them are non-cupped. I have an afterthought since posting this that I might look to repair them and cup one and keep one the way it is. I will give the prop guy the bronze one since I will never put it on. So now which one should I cup??
