oregoncruiser
- Oct 1, 2010
- 180
My new to me 2004 Larson 230 LXI is equipped with a Volvo Penta 5.0GXI. The current prop is a 3 blade aluminum, 14.25X21.
WOT is marked on the engine info tag as 4600-5000. Not sure what this means, that seems like quite a range to me. I attempted to reach WOT yesterday and was only able to achieve about 4250. At 4250 I was traveling 36 MPH according to the factory speedometer. I forgot to take my GPS in order to get a better speed.
I think I need to re-prop this boat in order to overcome a couple small issues. First, when turning tightly, the boat will 'skip' sideways across the water a bit. When this happens the boat loses speed and 'traction', and ventilates/cavitates (Yeah I've read the definitions and am still confused, I'll keep studying that). On a similar boat with similar issues, I re-propped with a 4 blade stainless prop and it solved the problems. So... the question now is what size/pitch??
Most of our boating is on low elevation lakes, 1000' or so. We do a lot of tubing, some skiing, and kneeboarding. The boat handles well generally speaking. It planes quickly, with little bowrise. Top speed is not a huge issue, although It is nice to be able to outrun a T-storm if necessary, LOL!!!
Suggestions??? Questions??? Thoughts???
