No Power
cape crusader
Hooking up the battery to the motor leads (+/-). But can't get the power trim on the motor to work.
Bob_VT
Re: No Power
Welcome to iboats.......
What kind of motor???
Each is different .......... do you have fluid? The electrical is VERY different on each brand too
cape crusader
Re: No Power
I have a Suzuki DF40 outboard. Have not used it it for a while. So I hooked up a brand new battery to see if I could raise and lower the motor and it did not. So I am not sure if there is something else I need to do. When I hooked up the battery it did not start that why I just tried to hook the battery to raise and lower the motor. Thank you in advance for any help. I just want to go fishing, etc.
Bob_VT
Re: No Power
Okay now I will move this to the Suzuki forum ;)
If it worked before....... my bet is on corrosion on contacts and wires.
99yam40
Re: No Power
Are you sure you hooked it up in the proper direction?
