Re: Yamaha 1.8 vs Mercruiser 3.0 reliability
I did an inspection once of an AR230. Really liked the boat, very good fit and finish. Here's a test on the 190. There are a lot of good things here, and with the single engine the economy isn't bad:
http://www.boattest.com/boats/boat_video.aspx?id=2583
This is more about whether or not you want a jet or an I/O. There is a lot different and generally speaking I don;t want a jet if I am in deep water. Some of that is pure snobishniss, and a jet can be a ton of fun. They are safe if you are worried about prop strikes, and of course contact with the bottom. They are very different to drive and that can be a negative safety issue until you completely understand how they work.
Same can be said for an I/O. Despite how well they track and steer etc. Boats are not cars, and for newbies either can get you in big trouble, and fast! I am not a jet hater, and I would not make this decision on fuel. In fact almost never should a boat decision be made on fuel. While it will be a huge part of your expense, the savings between two different setups is not going to make a difference of $20 on a typical weekend. I always say, you're gonna spend more than that on ice
These are very different packages, and you should be telling us more about what you plan to do with it, and where you plan to boat. What are other people running there? There may be reasons one setup is more popular than others. What do you want to do with it?
