Capt. Steelhead
- Jul 31, 2004
- 36
Hi Everybody, Like to replace my exhaust gasket on my '91 120HP force motor that's the one ties into the lower cowling if it's not available is high temp silicone the way to go for repair I have a gasket it has been in question about leaking and causing the motor to not idle correctly when the cowling is on. I just fixed up the motor new rings crank seals and one new piston. I would hate to put the thing all back together to have the same problem of a exhaust leak. I was thinking of that stove gasketing material to make my own the old one isn't in too bad of shape. Any input from you experts is much appreciated. Regards, Paul
