Locking washers on motor mounts
SeaRayboater95
Hi guys:
Found the locking washers on the underside of the motor mounts. How do I deal with these. Just bend them back, make the adjustment and bend them back again?
Thanks....
Ken.
04fxdwgi
Re: Locking washers on motor mounts
Just did this last week. Yup, bend em up, adjust, bend em back down. If you break one off, then you'll need to replace it (or use locktite in a pinch)
Hi guys:
Thanks....
Ken.
Ayuh,.... Exactly....
SeaRayboater95
Bit of a pain the %$s or back, as the case may be!! Got them loose, engine aligned, and drive on. Just have to oil it and lite it. Might not have time today as the temp is 2 celcius ( just above freezing for you guys down south). lol
...Ken
SeaRayboater95
Didn't get a chance to fire it up for the first time this season, but its all done and ready to go. Here is a couple of pictures.
Maybe next weekend...
Ken
Stripped down to bare aluminum,primed, painted and impeller,plate and gaskets.Also new decal and reseal kit on cylinders. Pretty happy with results!
