Hi
I replaced my old cracked engine with a complete 4.3 longblock,has a balancer shaft.Dont know if its a problem but the oil flow seems very slow in the heads.I have only run the engine on muffs,but there is no splashing or significant flow from the rocker arms at idle.When the engine is warmed up you can se a constant slow flow from the rockers.You could easily take the valve covers off when running at idle with no mess.
Im used to DOHC engines which simply baths in oil,im just wondering if this is normal.Engine has only been started 1 time,so I want to avoid any problems.Im using mineral 10-40w oil,and the oil pressure is normal according to mercruiser specs.
