Re: shift cable instal help..
Did you only replace the inner cable and not the outer shell? They need to both be replaced at the same time.
Or is it the outer that won't turn? You did leave the bellows off til the cable end was tightened, right?
If the inner cable is in the boat at a relatively straight angle you can tighten the outer end on the bell housing, then route the inner end to the shift plate. And after that you insert the inner cable from the transom end.
