sledhead28
- Apr 14, 2012
- 1
I have a 1980 Johnson 35 hp Model Number J35ELCSM. Im trying to do a water impeller replacement. do i need to lube top of drive shaft and seasl the top of plactic tube or is o ring thats on it good enough? Also do i need to put gasket sealer on the water pump housing or the plate before i bolt it back together? any help would be great. step by step even better
