seahorse 10 hp
- Apr 13, 2012
- 17
hello, my johnson sea horse was getting water in the gear case, so i took it apart put in a new o ring seal put it back together, and i can not get it into reverse now, the shift lever just will not go into reverse. i actually had to replace the lever due to breaking it. Also my tilt mechanism is not working, i have to undo the wing nut and take that bar out underneath the handle behind the motor in order for it to tilt, and those two hooks will not reach onto the tilt bar thing. I am quiete new with outboard but i reinstalled the lower gearcase using the manual, double checked it took it out a couple times and everything is in perfect order down there... but when i took the gearcase out the shift lever was able to go through fwd neutral reverse no problems, so someone told me it has to be the gearcase and something to do with te tilt.
any help would be so much appreciated...thanks alot!!!
