It runs waesome when at FT, but when attempting to start out or run at idle speed thru idle only zones it sputters and sometimes dies out. Especially when loading onto trailer it feels and sounds like it is being choked and does not have enough air and so it dies. It does become more difficult to re-start after this occurs too.
I use hi test gas, it runs 50:1 and i add an extra 1/2 oz for 5 gallons, I put SEA FOAM treatment on every other tank. Carbs look impecably clean on visual inspection and all floats and parts look to operate like they should.
Both filters (in-line) and the one on the motor are clean of any debris and clean overall.
being that other than this issue everything runs perfect I may just live with it, unless it will cause more problems for me later so pls advise if that may be the case.
What are my oprtions to remedy this problem?
Any and all suggestions are appreciated and welcome.
May all your fish be monsters and your days be safe
Thanks in advacnce.
-Reelfish
Thanks in advacnce.
-Reelfish
