My problems started 2 years ago with fuel issues. Ethynol is the start of the problem. I was amazzed at the amount of water that was absorbed in the tank. It started a steady down hill slide for the year. Last year I started fresh. New gas, New plugs. with a little advice from this forumn I had it fixed or so I thought.I think its flooding out on me..this is the symptom. It starts right up usualy on the second pull.. it idles nice..I put it in gear and give it throttle...it spurters a second and then takes off and runs fine for the most part. I'll get to my spot turn off the boat. starting it again is the problem. plugs are normally flooded. I have noticed something else at medium to low speed the rpms seem to rise in lower on its own. I have taken the carb off and cleaned it up..I'm starting to think that the float valve is sticking open possibly. it has a cork float. Am I looking in the wrong direction?
