I've asked this earlier this week without any replies, I really could use some help. I have a 1990,40hp Johnson and I have the water pump disassembled and the new parts in hand, but I can't get the key and impeller to go on the shaft together. I've got a M&R Manual for the motor and it says to install the key using grease to hold it in place. I've tried grease, double sided tape and you name it and I can't get the impeller to go over the key in the shaft slot.
What's the secret? I know someone has done this before and I could use any advise.
Thanks
Thanks
