Hello, I've got a 95 Mariner Magnum 40hp that overheats within 5 minutes. I have replaced the oil warning module and the oil pressure switch and the oil tank is full. That being said the alarm does stop when I disconnect the module. But, when I start the motor the water coming out of the tell-tale is immediatly warm, long before the motor is. After about two minutes the water is too hot to touch and then the alarm comes on a couple of minutes later. I have learned that this motor has no thermostats and regulates temperature through restrictions in the exhaust plate and other areas. My question is, is there a way to clean these areas out? I shredded an impeller a few months ago and am wondering if small pieces of impeller might be obstructing the water flow. Also, does this motor have a poppet valve, or some other way to discard water overflow? As always, any help is appreciated. Kyle
