what year and model
dashriprok
Does anyone know what year or model name of this boat is , i bought it and the trailer for 700.00 and i want to know what size engine to get for it , any help would be appreaciated this is my 1st watercraft and i am pretty green at all this 23523068_640.jpg23523069_640.jpg
Bob_VT
Re: what year and model
Welcome to iboats.
Look for a USCG label for motor size and loading capacity
It is always recommended that you have a motor that is least 75% of the capacity at a minimum
I have no clue on the make/model
dashriprok
Thanks for the info i will keep that in mind when the time comes
dashriprok
Thanks ! good guide to have . The previous owner ran a 40 HP and i probably start looking for something 30-40 i am assuming but i will make sure i get the proper motor for that size vessel .
Jeep Man
Looks like an early '70s Sunray. Can't say for sure, but most likely 60 hp would be max. 30 HP wll be underpowered, 40 hp will give you enough speed for cruising but not enough for skiing. 50 or 60 would be well suited.
It looks like a 14' model. If it is a 16', max maybe 75 hp.
MH Hawker
You should be able to get the year from the title, and that thier should be a data plate on the back some place that has the HP ratings.
