Re: Trailer Lights
I hooked my boat up to the harness and the lights did not work. It is the 4 prong one with the one rubber one on the end. The Weird thing is if I cut my headlights on they cut on but none of the signals work and if you hit the brake lights nothing happens. I have no idea what is going on... Any suggestions???
If I interpret it correctly, you are saying that the Tail Lights are working but both Turn Signal/Brake lights are not!
Sounds like the Ground(WHT) and the Tail Lights(BRN) circuits are OK.
The Left Brake/Turn(YEL) and Right Brake/Turn(GRN) are not!
Each "Tail Light" Bulb on the trailer has 2 filaments in them.
The Brake Lights and the Turn signal are the same filament.
The Brighter filament is for the Brake/Turn Lights.
The Dimmer filament is for the Tail Lights.
Before you go any farther, make sure you do not have a burned out filament on both sides.
Being the brighter filaments, the Brake/Turn filaments tend to burn out first.
You would not be the first person to have 2 bad bulbs.
It is way more common than one would tend to believe.
Then I would suspect a bad connection at the Flat 4 connector.
Turn on your emergency/4 way flashers in the truck and start shaking wires to see if you can get the Bake/Turn light to flicker.
