need your opion
todd choops
i have a 97 searay with twin io drives if after i run my boat and shut it off there's a little rainbow like fuel or oil leaking in the water around rear in the water is this normal or do i have a problem let me know what you think thanks
CharlieB
Re: need your opion
When were the drives last checked?
A leaking bellows can fill a drive with water, forcing oil out and leaving a sheen.
Check ALL fluid levels.
mark1905
Re: need your opion
Normal. A little unburnt fuel comes out of the exhaust when you shut her down.
Do check fluids and bellows though as a normal precaution.
