Re: 60ESL71C No fire on # 2 cyl
Now, here's a bit of trouble shooting you can do yourself or pass it along to the boat shop who will no doubt insist they install a new amplifier.
There is a plastic plug in connector leading from the amplifier that connects to a similar plastic connector that leads to the timer base. Unplug it. Remove all of the spark plugs in order to avoid injury.
With the key in the "ON" position, tapping thee lead from the amplifier you unplugged will simulate the opening and closing of the ignition points.
Rig a spark tester if you have one or build a tester such as one I list below, then connect the coil wires from each cylinder to it. Set the gap on the tester to 1/4".
Now, tap that amplifier lead on the block to simulate the point opening/closing while you slowly turn the flywheel. When the bakelite rotor under the distributor cap aligns with any of the three coil wire terminals, that will cause one of the coils to fire at the tester. By the same token, if the #2 terminal of the distributor cap is shorted, you will certainly hear it snapping under the flywheel.
(Spark Tester - Home Made)
(J. Reeves)
A spark tester can be made with a piece of 1x4 or 1x6, drive a few finishing nails through it, then bend the pointed ends at a right angle. You can then adjust the gap by simply twisting the nail(s). Solder a spark plug wire to one which you can connect to the spark plug boots, and a ground wire of some kind to the other to connect to the powerhead somewhere. Use small alligator clips on the other end of the wires to connect to ground and to the spark plug connector that exists inside of the rubber plug boot.
Using the above, one could easily build a spark tester whereas they could connect 2, 4, 6, or 8 cylinders all at one time. The ground nail being straight up, the others being bent, aimed at the ground nail. A typical 4 cylinder tester follows:
..........X1..........X2
.................X..(grd)
..........X3..........X4
That's about as easy as I can make it. Let us know what you find.
