boating maniac
- Jun 12, 2011
- 103
My johnson 1991 140hp johnson outboard keeps misfiring below 1300rpms or so. It misfires every 4 seconds or so. Other than that it runs fine at all other rpms. How do I fix this? I just decarboned it and changed out the spark plugs and changed the fuel filter. I had the dealer do the thermostats and they messed up the idle speed again. Everytime they work on something they mess around with the idle speed and it does this. They did this last season and I adjusted the idle speed and it ran fine but now this year even though I put it back to where it was it's still missing. If you take it out of gear it goes up to about 1100rpm this misses and drops down to 700 and repeats. I don't know if the only way to fix this is to clean out the carb or just leave it and see if it gets better. I always use stabilizer in the fuel.
