Open Waters
- Aug 14, 2011
- 32
Hello all,
I'm replacing the original prop on my L-Drive. I used i-boats to select the appropriate prop. Too my situation.....
When removing my old prop I noticed there was a thrust washer, or "thru-hub spacer as printed on the back of it", between the hub and the gearcase. Before installing my new prop, I decided to leave the said spacer/washer in place. After installing my new prop, I noticed a gap between my hub (barrel) and the gearcase (see pictures). I thought this looked strange. So I took off the new prop, removed the spacer/washer, then reinstalled the new prop. After reinstallation, the gap closed but the prop felt hard to turn.
My question.... Is this gap ok or should I return my new prop and bye a different one.
Thanks in advance.
Open Waters
Thanks in advance.
Open Waters
