I'm looking for an expensive and hard to find 4" double sided manifold stud. I've found I can get some industrial threaded studs (316 stainless) that are the correct length/diameter. I can get 316 stainless nuts for them as well. Can I use them instead of the factory threaded stud/smooth shank/threaded stud ones? The difference in price is $80 that I can use on other parts the engine needs. What do you think? If I need to, I can use an epoxy putty to smooth the middle of the shank out if it is needed. Any advice?
