Re: omc cobra 5.0 interuptor switch doesnt work after upgrading ignition ....
Im not sure mzahn, I'm pretty sure i had the piston up on tdc cause my old rotor was pointing pretty much at the number one cylinder when i pulled it off. I turned the motor over several times by hand with the old distributor cap off to make sure the piston was up. So my plan is to keep messing with it until it gets closer I guess. Haven't had a chance to start on the interuptor side of it all, Im sure I will have some questions as soon as I get to that part of it....
You do realize there are two periods where the engine will be at TDC during a normal 4 stroke combustion cycle, right? The first TDC is at the end of the compression cycle right before the ignition cycle. The second TDC is at the exhaust cycle. When you set up the engine for #1 TDC to drop the distributor, you want the engine on compression TDC.
If you are brave, you can sick the tip of your finger loosely in the #1 spark plug hole, and feel for the spinning engine to push air out past your finger. At that point you line up your balancer with the 0? mark, and drop your distributor. If sticking you finger in the hole gives you the heee-be jeee-bees. You could also pull the valve cover for the odd bank of cylinders, and spin the engine over while watching your rockers go though their motions. You would be looking for the #1 intake rocker to open and close the valve, and at that point line up the balancer to 0? TDC.
As far as issues with dropping your distributor, as Reinell said, the oil pump shaft needs to be properly aligned with the distributor shaft. If the distributor refuses to fully drop, you need to look down in the distributor hole, and you will see a slotted shaft at the bottom (this is the oil pump drive shaft). You simply take a
long slotted screw driver, and spin that shaft by hand until it will allow you to drop the distributor with the desired rotor position for #1 cylinder. It isn't etched in stone that #1 needs to be located at a certain point on the distributor. Just for the sake of simplicity, it is usually recommended that you line up the rotor pointing at #1 cylinder with #1 cylinder at compression TDC
