Re: raw water flow/blockage
I pulled the heat exchanger and it looked brand new. It normally runs at 175. Mechanic at local marina said it should run at 160?? Owner of marina said the 224's traditionally ran warm. Said he even heard of dealers putting resistors in the temp guages?? After hitting the sand bar and overheating I let it cool & headed back to the dock. Have to do a 15 minute no wake trip to get there. On that 15 minute trip it really started running crappy, missing, stalling, etc. (Don't think it had anything to do with overhat, that was the impeller) Figured I had better do a tune up before anything else, to cancel that stuff out. What I am thinking now is that it was the shift interupt switch, I know I kept pulling the throttle back as far as I could because I thought I was going too fast down thru the no wake zone. I shouldn't have messed with it. It runs great once it gets on plane. Trouble now is I can't get the idle down to specs. Lowest I can get it to is about 1100 rpm in the driveway. Haven't got into the water since adjusting the timing last. Gonna float it tomorrow, weather permitting.
